Ported Ford 289 heads with port energy discussion
Carnut1
Post by Carnut1 »
mag2555 wrote: Fri Nov 10, 2017 6:43 am There ya go, now that's looking way better!!
Anybody ever try out long reach spark plugs in these Heads during a dyno session?
They look like a great candidate to me!
I would but I would grind the extra threads off to keep them from overheating and causing a detonation issue.
mag2555 wrote: Fri Nov 10, 2017 6:43 am...Anybody ever try out long reach spark plugs in these Heads during a dyno session?..
Bad idea to allow any thread to extend into the chamber. At best it will carbon up and screw up the threads, at worst there's risk of it turning into a glow plug.
BILL-C
Post by BILL-C »
I've never seen a "long reach" 18 mm spark plug before for 289 heads. What does it look like?
Carlquist Competition Engines
David Vizard
Post by David Vizard »
Hey super Mag - do you mean extended nose plugs?????
DV
NXBOY
Post by NXBOY »
How about the adapters that allow use of a ton of different 14 mm plugs?
BILL-C
Post by BILL-C »
Tell me more about these 'adapters' to put the 14 mm plugs in place of the 18mm originals.
Newold1
Post by Newold1 »
Hey Bill, those are made and distributed by that same company that makes those valve stem length extenders ! :lol:
mag2555
Post by mag2555 »
Yes David,to me these Heads look like they would love to have the flame light off way more in the middle of the chamber, no?
A colder plug , and yes the grinding off of the excess unused threads would need to take place as posted also.
In-Tech
Post by In-Tech »
BILL-C wrote: Sat Nov 11, 2017 6:23 am Tell me more about these 'adapters' to put the 14 mm plugs in place of the 18mm originals.
I believe Timesert makes a triple oversized Bigsert that is larger than 18mm and necks down to 14mm.
-Carl
BILL-C
Post by BILL-C »
Looks like a very risky procedure with low likelihood of any gain.
In-Tech
Post by In-Tech »
LOL Bill, I didn't say I was going to do it. :lol: But, if I was going to do it, I'd just lathe up some "adaptors". :) My post was just to show there looks to be an alternative for guys without access to a lathe. :wink:
-Carl
NXBOY
Post by NXBOY »
Bill-C You can Call REAM Richardson Engineering and products, They make adapters but for a tapered plug And they will make the same adapters as Garrett Machine used to, alot of people on the Bigblock Forums used to use them. Talk to John and said around 10 bucks. These are for 3/4 reach but i'm sure he can make for 5/8 or what ever you wanted cheap. Made of same material as a plug. 1-9892770141
BILL-C
Post by BILL-C »
Thanks for the info.
Newold1
Post by Newold1 »
Now somebody get me some pics of that valve stem length extenders! HA :D
cgarb
Post by cgarb »
Valve stem length extender...
