Warp Speed
Re: Which Is Faster - 600hp@6200 or 600hp@7100
Post by Warp Speed »
Why the contradictory data from paper to track?!?
:wink:
randy331
Post by randy331 »
plovett wrote: Fri Nov 10, 2017 5:31 pm
randy331 wrote: Wed Nov 08, 2017 11:46 am
I did a 383 ( Pseudo )
Why is the 383 called "Pseudo"? Just curious.
paulie
Pseudo
[soo-doh]
1.
not actually but having the appearance of; pretended; false or spurious; sham.
2.
almost, approaching, or trying to be.
Origin of pseudo
Figured that described it. "Trying to be" or "having the appearance of" a race engine. un-ported heads and just other left over stuff in the shop.
It'd have a little thump like a race engine, smell like one, just didn't figure it'd be an over achiever. LOL
Randy
Stan Weiss
Post by Stan Weiss »
Warp Speed wrote: Fri Nov 10, 2017 7:29 pm Why the contradictory data from paper to track?!?
:wink:
Jay,
I must have missed it. Can you post a link to these HP / Torque curves? All I have seen posted is a single data point from a number of different curves. Have you never dynoed an engine and had peak HP go down but other areas in the curve also changed and the engine ran faster?
Stan
user-17438
Post by user-17438 »
Stan Weiss wrote: Fri Nov 10, 2017 9:25 pm
:wink:
Jay,
Stan
Back in 05-07 our sb2 program had identical engines make same power curves within 1 percent. Yet brake specifics were different, and some would out accellerate the others. A steady state dyno test at 300rpm/sec will show more hp than 600rpm/sec on the same engine. From my experience in racing, who cares what the torque is. Rpm and horsepower matter.
The only thing I care about when I comes to torque is how slowly it drops off.
plovett
Post by plovett »
randy331 wrote: Fri Nov 10, 2017 8:26 pm
paulie
Pseudo
[soo-doh]
1.
2.
Origin of pseudo
Randy
I thought maybe it was a pseudo 383 because Chrysler had two 383's before the Chevy one. :)
vortecpro
Post by vortecpro »
MTENGINES wrote: Fri Nov 10, 2017 11:56 pm
:wink:
Jay,
Stan
Well said.
Stan Weiss
:wink:
Jay,
Stan
So you produce dyno sheets without torque. :? I have never seen one produced that way.
How about doing a fixed load variable acceleration rate (RPM/sec) test more like a car running on a race course?
Stan
Roundybout
Post by Roundybout »
Let's throw an electric car into the mix.
1000 lb/ft from 0rpm to 3150 rpm
750 lb/ft at 4000 rpm
600 lb/ft at 5000 rpm
509 lb/ft at 6200 rpm
What does an infinitely variable transmission do with that for max performance?
Frankshaft
Post by Frankshaft »
Roundybout wrote: Sat Nov 11, 2017 6:54 pm Let's throw an electric car into the mix.
This isn't directed towards you, so don't take offense, but who gives a SHIT. This isn't a electric car site, and I hope it never is. They can pound electric cars you know where
Warp Speed
Frankshaft wrote: Sat Nov 11, 2017 8:04 pm
Amen!
swampbuggy
Post by swampbuggy »
X 3 Mark H.
nitro2
Post by nitro2 »
X4
TFX Engine Technology Inc.
tfx.engine@yahoo.com
www.tfxengine.com
user-23911
Post by user-23911 »
30 pages of bullshit now.
Why get upset about lectric cars. My next one will be lectric.
It's because someone mentioned torque at zero RPM which jammed a spanner in the works.
Which proves you can have torque without power but you can't have power without torque, with an engine or motor.
What about steam engines?
Same, it's torque that gets it started.
Geoff2
Post by Geoff2 »
Joe,
Best of luck of luck when you break down with error code 543 on the dash & you ring a local repair shop for assistance....
user-23911
I fixed a Prius about 8 years ago when the owner of one of the local machine shops imported it from Japan with a flat battery.
Today I've got a 5 year old's lectric car in the garage............managed to put the smoke back inside it (owner tried to rewire from 12 to 24 volt).......then an electric scooter turned up. The owner wants it fixed so he can get home from the pub without having to drive the car when he's pissed.
