SBC Holley sniper sheet metal intake
SPDYPETEY
Post by SPDYPETEY »
Just obtained a motor
Engine is a 385ci pump gas motor. 4.040/3.75 stroke
Track 1 heads
Comp soild roller
Holley sniper int.
Any info on this intake or people who have had any experience or negative feed back I'd appreciate..
TO ME SEVERAL CYLINDER S RUN DIFFERENT THEN OTHERS.. THANK YOU.
FC-Pilot
Re: SBC Holley sniper sheet metal intake
Post by FC-Pilot »
You are the first person I have heard of that has one of those things. Is it the single carb or dual carb intake as I have seen images of both. I would love to get my hands on one to play with on the dyno to prove/disprove that it works or not. The general layout has me scratching my head.
Paul
SPDYPETEY
Post by SPDYPETEY »
I'm sorry single carb. I cannot find anything on it. Somebody's must of dynoed??? We ran in the 10s w it on motor . Pump gas 385. In S10 w pg and 3.73 nos converter.. I will see Fri on nos how it works then switching to super vik.. Thank you.
FC-Pilot
Post by FC-Pilot »
Keep us posted on how it works and the change good or bad when you go to the super victor. Good luck.
Paul
SPDYPETEY
Post by SPDYPETEY »
Thank you.. Merry Christmas and Happy holidays
mag2555
Post by mag2555 »
Are we talking mix differences on the dyno, or on the track?
The single Carb version may have too much Plenum volume?
SPDYPETEY
Post by SPDYPETEY »
Both. I'd like too see on Dyno and I Will track test after this weekend.. Thank you
mag2555
Post by mag2555 »
Is it breathing thru a scoop at the track?
SPDYPETEY
Post by SPDYPETEY »
No sir. Cowl hood. have 4.75" clearance. I may try a scoop too see. Thanks
SPDYPETEY
Post by SPDYPETEY »
Update
My buddy took our S10 to track. I was very disappointed W the performance of motor..
Supposed to be 385 ci
.040 350
3.75, flat top motor
Track 1 heads ported
Holley sheet metal sniper intake.
Stops pulling at 6300
Cam solid roller 260/270@050 , 686/686 110
Qft 850 annular booster
36* timing..
Truck went 11.80@107 on motor. Leaving at 4200 on break. Hookd and left like BREAD TRUCK
Granted tight 9.5" Fti NOS Converter w PG trans
3.73 Gear w 28x10 slick
Nitrous pass w an 85 jet 5.25* fp pull 10* total(26) on NOS
9.70@135. . IM CHANGING INTAKES TO A SINGLE PLANE SUPER VIK.
THANKS AND ENJOY YOUR WEEKEND.
FC-Pilot
Post by FC-Pilot »
Keep us posted on what changes you have to make tuning wise as well as performance changes.
Paul
rustbucket79
Post by rustbucket79 »
Lots of duration, low compression, low stall and a 2 speed make a weak combo. The nitrous (gobs of torque on the launch) show the potential of the combo. A manifold change will help if it builds torque around your stall point.
The truck will never be quick on motor without converter and gearing changes, at which point you won't have the RPM available for the spray.
BTW, nice runs going 9's =D>
