Timing Chain, End Play and Cam Button
pamotorman
Re: Timing Chain, End Play and Cam Button
Post by pamotorman »
you do not want the cam gear to move outward any amount as the Torrington bearing can slip out of place. the pressure of the cam gear inward towards the block is what holds it in place. use a needle bearing not the plastic thrust bearing. https://www.speedwaymotors.com/Small-Bl ... _dEALw_wcB
tenxal
Post by tenxal »
Set the heads and intake on with a couple of bolts, drop the distributor in and snug it down and then check things up front.
Walter R. Malik
Post by Walter R. Malik »
RD_Racing wrote: Sun Dec 17, 2017 11:00 am This morning I rotated the motor over a few times to let the upper cam sprocket fall where it does. I then put an indicator on the face of the cam sprocket and could push it in .009
The cam gear already has a roller thrust plate built into it, can I just add a regular thrust plate behind it? Comp Cams makes one that is .020 (cant find one thats only .010 thick) and by adding that, it would eliminate all rearward movement and keep constant contact on the block.
I was thinking you were talking about .090" or so. .009" is not going to be an issue; the crankshaft thrust will be some part of that.
pamotorman
tenxal wrote: Sun Dec 17, 2017 11:27 am Set the heads and intake on with a couple of bolts, drop the distributor in and snug it down and then check things up front.
without the friction of the oil pump moving oil i don't think this will prove much
geraldtson
Post by geraldtson »
RD_Racing wrote: Sat Dec 16, 2017 5:55 pm Is the cam timing gear position pretty much located by the crank timing gear? The lower crank gear is a fixed position (press fit) and since the cam timing gear has nothing to hold it in place, doesnt the in/out positon of the cam sprocket get located by the position of the crank gear and the chain thats locating it?
With that said, I just installed a new Solid Roller cam and timing chain (comp #7100) which has a built-in thrush bearing and with the crank gear fully seated, the cam is being pulled out slightly by the chain and my thrush bearing isnt making constant contact with the block.. Also when i put the timing cover on (with the gasket) I have no clearance between the cam button and timing cover because of this too. Is there any way to resolve this?
Sorry, I'm still learning here.. Thanks for any help or explanation
Install with timing cover,button and timing cover gasket your going to use.Tighten cover down,this will pull cam back into position. Now make sure lifters are riding centered on cam lobes (should be close). If not center lifters by removing material from end of cam button or adding longer button (usually not needed with correct assembly). At this point you probably want have any endplay (check). What i usually do is add one or two extra timing cover gaskets to get some endplay,or you can grind material from cam button. A lot easier to add a gasket or two. I always pull intake and recheck where lifters are riding after some run time if possible. Usually things are OK.
RD_Racing
Post by RD_Racing »
geraldtson wrote: Sun Dec 17, 2017 6:23 pm
Thank you very much for explaining.. Do you still want end play on a roller button too?
geraldtson
RD_Racing wrote: Sun Dec 17, 2017 7:25 pm
YES!! Same endplay as nylon cam button. Without endplay the steel roller button will come apart on you! I've used both. The nylon buttons are more forgiving. I only use steel roller button if timing chain cover has mutual (thrust washer) surface to match (stiff and round) small end of steel roller button. Many different timing covers out there.
pamotorman
i always used this type of cover with a "Y" shaped steel reinforcement brazed into the "Y" groove on the cover.
geraldtson
pamotorman wrote: Sun Dec 17, 2017 9:18 pm i always used this type of cover with a "Y" shaped steel reinforcement brazed into the "Y" groove on the cover.
I always did the exact same thing!! Used to scrap pretty much everything on the motor sometimes but i would save those timing covers!
NewbVetteGuy
Post by NewbVetteGuy »
geraldtson wrote: Sun Dec 17, 2017 7:44 pm
I hope the OP doesn't mind, but I'm trying to figure out the timing chain, cover, gasket, cam button, & timing tab for my GEN1 SBC with retro roller cam, too, and I had the same question.
Why do you want the end play vs. no end play? Can you explain this a little bit more? Is that point that in general, you don't want the roller button to actually be contacting the cam at all, but when you end up in a condition that pulls the cam forward (rapid decel???!?) the roller button simply stops it from moving too far forward and is only spinning for a short period of time after which the cam snugs back up to the block surface / torrington bearing?
NewbVetteGuy
If I should start a new thread, I can, but I'm also curious what the process looks like to measure the end play when you're doing this with the engine in the car...
I've heard the 2 piece Cloyes covers makes setting the end play with the engine in the car much easier (not clear on why)...
rfoll
Post by rfoll »
The idea is to limit end play to a certain amount. I was just checking the specs on a cam using a stock silent chain that appears to be in good shape. The cam can be pulled out of the block nearly 1/4". On the stock stuff this timing set came from, it probably didn't matter. In a performance app, It's not what you want.
RD_Racing
Post by RD_Racing »
NewbVetteGuy wrote: Mon Dec 18, 2017 8:08 pm
I don't mind, all my questions have been answered..
Tom Walker
Post by Tom Walker »
You need a little clearance for the expansion of the parts as the engine heats up in operation.
NewbVetteGuy wrote: Mon Dec 18, 2017 8:10 pm If I should start a new thread, I can, but I'm also curious what the process looks like to measure the end play when you're doing this with the engine in the car...
Some of your questions are answered above, but to summarize:
o As per earlier post, end play must be controlled to prevent the helical distributor drive gear's movement from altering spark timing.
o Flat tappet cams are ground with a couple of thousandths taper across the face, which allows spring force to hold the cam rearward with the cam gear thrust face against the block.
o Roller cams have no taper ad require some other locating mechanism.
o End play can be measured several ways. I prefer using a test indicator https://www.google.ca/search?q=test+ind ... 45&bih=885 down through one of the drain holes above the cam and contacting the front or rear of a lobe.
o Many two piece covers (e.g. Cloyes and clones of same) have a threaded externally accessed thrust bearing that allows easy adjustment.
o Rather than me typing it all out here, Google "adjusting SBC cam end play" for 106,000 explanations.
