WTB Tappet resurfacing machine
Preferredservices
Post by Preferredservices »
I am looking for a sunnen or tobin arp tr-6700 dead or alive to add to my shop please pm me if anyone can help thanks Dave
ProPower engines
Re: WTB Tappet resurfacing machine
Post by ProPower engines »
There are several of us here looking.
Webb also made a machine similar but for storm vulcan back in the day.
Just as a note there is a machine made overseas that will do the job and was made for just this purpose.
I was going to do an FYI post when I get the details about it. It will also do lifter buckets as well as bucket shims.
Preferredservices
Thank You I dont mind sending them out to get done but when I need a set same day its not working out I was thinking of putting a collet head in my lathe and using a pedestal grinder with a good cup wheel I just dont have a good way to set the degree plus the mess on the ways and everything .
ProPower engines
I was looking at getting a speed reducer angle drive like a crank polishing stand uses and mounting a collet chuck to it.
The grinding wheel can be oriented to adjust the grinding angle mounted to a plate that is on a table that slides on another table with a slot to set the degree of angle for the correct radius.
A small coolant pump for VG oil for cooling and the tank would be under the top as part of the complete assembly.
Like the storm vulcan setup.
I figure maybe $500-$750 to get it done completely
Sorry for not being in the right thread but when ideas come up ya know how it is :lol:
Preferredservices
Latest update picked this up from a friend for $500 bucks [img]
Michaelfrompa
Post by Michaelfrompa »
Not to say you cannot use that for lifters......but it IS a tool and cutter grinder.....and as most of these types, does not rotate the piece being presented to the wheel, except by hand................The tappet grinders we all use/desire....rotate the lifter as it is ground. Good Luck anyway.....
