Thanks John! That is a big help! What type of shocks do you use? Varishock?John Wallace wrote: ↑Wed May 30, 2018 8:23 am Not sure on the spring rate.
It depends on some data on the suspension, around 200 lbs probably?
Try this link:
Spring Rate
I made many launches on my car to see where the bars needed to be for a good 'hook'.
(I have ladder bars though, 4 links lot more adjustments)
Some made a huge improvement in hooking. Then start on the springs, then the shocks.
Critique 1/4 mile run
Re: Critique 1/4 mile run
- John Wallace
I bought them a long time ago, seems like they were Strange possibly?
John Wallace
Pontiac Power RULES !
www.wallaceracing.com
Thats who I planned on going with but Varishock is made in USA also.John Wallace wrote: ↑Thu May 31, 2018 11:44 am I bought them a long time ago, seems like they were Strange possibly?
- af2
Summit had a sale on theirs when I bought them, made by Strange and saved $100 on the pair. I am running 95 lb springs.
The most important thing is to scale the car when you change.
GURU is only a name.
Up date! New low et. 1.447, 4.150, 6.448, 106.44, 8.446, 10.148, 131.69. Sluggo off the line but a 25.25 mph gain in the top 1/2 of the track!!!! What do you guys glean off this info you can help me with?
Post by redliner » Mon May 28, 2018 12:03 pm
Hi guys, Can you tell me what you think of these numbers and where there is room for improvement? Thanks! 414 sbc, 11.5-1, Liberty faceplated TKO 600, 4.88 Olds in a 1942 Stude Champion coupe. 3100 lbs. 60'- 1.446,330'-4.262,1/8- 6.587,mph- 105.59, 1000'- 8.597,1/4- 10.306,mph-131.02
more Info for you to look at :
good correlations :
Thanks Max! It looks like ( as I knew) my bottom end lacks alot! What is your opinion ?maxracesoftware wrote: ↑Wed May 29, 2019 2:24 amCritique 1/4 mile run
Hi guys, Can you tell me what you think of these numbers and where there is room for improvement? Thanks! 414 sbc, 11.5-1, Liberty faceplated TKO 600, 4.88 Olds in a 1942 Stude Champion coupe. 3100 lbs. 60'- 1.446,330'-4.262,1/8- 6.587,mph- 105.59, 1000'- 8.597,1/4- 10.306,mph-131.02more Info for you to look at :
good correlations :
a typical NHRA SuperStock SS/J Class Car will accelerate to these ET/MPH times :redliner wrote: ↑Wed May 29, 2019 7:02 pmThanks Max! It looks like ( as I knew) my bottom end lacks alot! What is your opinion ?maxracesoftware wrote: ↑Wed May 29, 2019 2:24 amCritique 1/4 mile run
good correlations :
anywhere from 1.370 to 1.382 60 Feet ET's ....so you should expect to reach those numbers
with better Launch/Traction Hookup
Code: Select all
Feet ET real MPH (*Time Slip MPH)
60= 1.3820 46.1644
330= 4.1240 85.0472
594= 6.0103 104.3876
660= 6.4340 107.9873 (*106.1874)
934= 8.0692 120.3856
1000= 8.4390 122.9538 (*121.6697)
1254= 9.7986 131.5975
1320= 10.1380 133.5747 (*132.5861)
0 to 30 MPH ET= 0.6392 at 18.0 Ft
0 to 60 MPH ET= 2.2084 at 124.6 Ft
0 to 80 MPH ET= 3.6957 at 278.1 Ft
0 to 100 MPH ET= 5.5234 at 521.0 Ft
0 to 120 MPH ET= 8.0147 at 924.4 Ft
0 to 140 MPH ET= 11.3289 at 1559.0 Ft
Ft ET MPH GForce
-1 -0.1935 0.0000 0.0000
0 0.0000 7.0462 1.6598
and your HP output is similar ,
however, your HP output after 1000 FT starts to fall-off as compared to a SS/J car
so i'd look for the cause of this .
you should be around 132+ MPH at 1320 FT ET Slip MPH,
and not just 131's
THANKS! I see yer point! I am just sorting this combo and have only worked my way up to 35 degrees of timing which retards to 34 degrees. I will try bumping the timing up to 36/35 and see what happens, yer thoughts?maxracesoftware wrote: ↑Thu May 30, 2019 12:16 pma typical NHRA SuperStock SS/J Class Car will accelerate to these ET/MPH times :
your acceleration rate starts to match the SS/J Car's around 660 FT upwardsCode: Select all
Feet ET real MPH (*Time Slip MPH) 60= 1.3820 46.1644 330= 4.1240 85.0472 594= 6.0103 104.3876 660= 6.4340 107.9873 (*106.1874) 934= 8.0692 120.3856 1000= 8.4390 122.9538 (*121.6697) 1254= 9.7986 131.5975 1320= 10.1380 133.5747 (*132.5861) 0 to 30 MPH ET= 0.6392 at 18.0 Ft 0 to 60 MPH ET= 2.2084 at 124.6 Ft 0 to 80 MPH ET= 3.6957 at 278.1 Ft 0 to 100 MPH ET= 5.5234 at 521.0 Ft 0 to 120 MPH ET= 8.0147 at 924.4 Ft 0 to 140 MPH ET= 11.3289 at 1559.0 Ft Ft ET MPH GForce -1 -0.1935 0.0000 0.0000 0 0.0000 7.0462 1.6598
and not just 131's
