406ci SB2.2 STEELBLOCK
Engine # PRE357
Bowtie 1184 block - 4.120 bore - 50mm cam tunnel
Callies Magnum crank - 3.800 stroke - Honda journal rods
Dyers 5.850 - 300M rods
JE -13cc - 1.145ch -pistons
Finish First SB2.2 heads
2.180 - 5.700 - 5/16 - 50* titanium intake valves
1.600 - 5.590 - 11/32 - 55* titanium exhaust valves
Jesel 1.85 - 1.80 shaft rockers
PAC 1387 valve springs
Comp Cam 8620 billet steel 50mm cam
Isky .904 EZ Roll lifters
Edelbrock 2962 intake
Cast aluminum valve covers
MSD dual pickup distributor w/cap a dapt
MSD sparkplug wires
Stewart stage 3 waterpump
Dan Olson single stage wetsump oilpan
ATI balancer
Jones serpentine pulley set
Bosch F08CSO sparkplugs
13:55 compression
30* timing
Valves .014 - .016 hot
Dynoed on 8 -1 -23
805hp @ 7300rpm
621# torque @ 6200rpm
$16,500
Pictures are available by email
Phone: 865-250-7985
EMAIL: terry.marciaburnett@gmail.com
406ci SB2.2 STEELBLOCK ENGINE
