Spring lenght effect
BOOT
Post by BOOT » Sat Nov 02, 2013 9:31 pm
Ok so if I want to compare two coilover springs, say for example a 10"-175 and 12"-175 same diameters and say the use was designed for a 10" coilover with adjustablilty. What's gonna happen, less travel, coildbind?
What about a stiffer rate 12" spring?
Confused
Re: Spring lenght effect
Post by Confused » Sun Nov 03, 2013 11:03 am
Hieght has no effect on rate. If the coilover was designed for a 10" spring, using a 12" will move the adjuster nut down 2". That may put it at the bottom or of the threaded section of the shock.
BOOT
Post by BOOT » Sun Nov 03, 2013 11:24 am
Ok I was thinking it wouldn't, but does a taller/longer spring have more stored energy?
Confused
Post by Confused » Sun Nov 03, 2013 12:09 pm
I don't believe it does.
BOOT
Post by BOOT » Sun Nov 03, 2013 1:01 pm
Ah nm I see it travels longer
Bubstr
Post by Bubstr » Sat Nov 23, 2013 4:40 am
Spring rate should be as advertised on both. The longer one will have more travel. Both can only store the energy put in them and give it up at the advertised rate. 175lb will store 175 lb for every inch they are compressed and they give up 175lb for every inch of separation. Note, where the shock is located on the lower control arm or rear axle in relationship to the contact patch will change effective wheel rate.
rdkonkel
Post by rdkonkel » Thu Jan 02, 2014 10:13 pm
What about a lower rate 12" spring with some preload put into it? So the rate at 1" of travel equaled the 175# spring. Then there should be more useable travel. Haven't tried this yet but I was thinking about it on my dirt modified.
Confused
Post by Confused » Fri Jan 03, 2014 6:30 pm
The spring has "pre load" when the car is sitting on them. If I understand your question correctly, with 1" "preload", the second inch of travel would be at 175? This would make the spring rate 85~pounds/inch. At that rate, on an IMCA type Modified, you would need a 16" spring or longer.Whichever spring is in the car, is only going to compress enough to hold the weight. The softer the spring rate, the more compression required.
flyingwedge
Post by flyingwedge » Wed Jan 08, 2014 1:03 pm
BOOT wrote:Ok so if I want to compare two coilover springs, say for example a 10"-175 and 12"-175 same diameters and say the use was designed for a 10" coilover with adjustablilty. What's gonna happen, less travel, coildbind?
>> That 12" x 175lb. spring can effectively support 350lbs. more load, than the 10",(2" x 175lbs). Set your spring preload for initial rate,(static ride height), and make sure it doesn't coilbind, at full compression. As a side note, the 12" spring will have more "resilliance", something to consider in a street vehicle. Good Luck, flyingwedge.
