rant: why do people call iron heads steel heads?
Open to topics unrelated to Speed-Talk.
No politics. No religion topics.
Re: rant: why do people call iron heads steel heads?
Post by pdq67 »
Aluminum and steel are generally continuously cast.
Check ALCOA for concast slabs. They can be as big as one per flatbed load.
And check US Steel, Edgar Thompson Works for concast steel that is being rolled into sheet that then is rolled up like toilet paper. These can be as big as one roll per flatbed. Also rolled to make pipe as well as thick slabs, H and I beams and even angle-irons and such.
I have worked in several aluminum and steel integrated mills and steel mini-mills through the years so have watched both operations creating product.
Right, the concast slabs and even cast ingots are reheated in reheat furnaces and then rolled to make shapes/sheets that are then turned into products.
They will take a concast piece, roll it into a slab then forge it into shape to create a billet that is then machined into a part or a regular forging.
77cruiser
Post by 77cruiser »
I wonder if steel heads are worth more than cast iron heads? #-o
Jim
user-23911
Post by user-23911 »
77cruiser wrote:I wonder if steel heads are worth more than cast iron heads? #-o
Well that's what it's all about really.
Salesmen?
If it's cast, it must be iron.
If it's steel , it automatically means that it's forged so it's worth lots more.
ChevelleNut
Post by ChevelleNut »
dave brode wrote: Tue Feb 17, 2015 10:52 am On that subject, aren't "billets" actually a casting? So, if true, doesn't a billet crank start from a casting?
No. Billets are machined from a solid chunk of material.
ChevelleNut
I've never heard anyone call them steel heads.
BCjohnny
Post by BCjohnny »
ChevelleNut wrote:
dave brode wrote: On that subject, aren't "billets" actually a casting? So, if true, doesn't a billet crank start from a casting?
I think the point that's maybe being made is that all 'billets' start out as 'castings', ie liquified steel being poured into a mould to solidify, and then subsequently processed ...... rolled or forged etc ...... into the raw billet
Mostly these days by the 'continuous casting process'
dave brode
Post by dave brode »
ChevelleNut wrote: Wed Apr 14, 2021 10:37 pm
Yes, but do they not start as a casting? [poured as molten metal into a mold of some sort.
Like a "forged" piston, is cast, then hit with forging dies.
dave brode
ChevelleNut wrote: Wed Apr 14, 2021 10:37 pm I've never heard anyone call them steel heads.
All the time on FB Marketplace.
Here is where it started imo:
http://www.racingin.com/Series/SteelBlockBandits.aspx
emsvitil
Post by emsvitil »
Maybe they meant to say
Steal
:twisted:
Ed
enigma57
Post by enigma57 »
](*,) Oh, dear! So do I look for engine mounts or motor mounts then? Or rubber vibration transference isolators? Or perhaps rubber vibration absorptive containment devices? It's all so confusing......
HB
77cruiser
Post by 77cruiser »
viewtopic.php?f=31&t=62574
Jim
dave brode
modok
Post by modok »
At one time I tended to call any white mystery metal i encountered "zinc"
But that went away as I learned to actually identify "white metals" such as lead alloys, tin alloys, babbitt, zamac, pewter, cupro-nickel, magnesium, ect.
Billet means it was carved out of a solid piece of material. Usually good quality material is used.
Tho if you had a solid block of melted down licensee plates...I'd say that's still a "billet". :P
Racing68
Post by Racing68 »
Probably the same reason some track rules in my area state NO NITROUSMETHANE, they don't have a clue and go by what others have said in the past.
77cruiser
Post by 77cruiser »
Racing68 wrote: Tue Jul 13, 2021 6:45 pm Probably the same reason some track rules in my area state NO NITROUSMETHANE, they don't have a clue and go by what others have said in the past.
If that's official nitromethane would be legal.
Jim
