Waukesha D176 crank failure???
Chipped tooth
Post by Chipped tooth » Sun Dec 20, 2015 9:31 pm
Just picked up a Clark off-road forklift for the shop the other day that needs engine work
Any ways I just pulled the engine tonight and found the crank broken right behind #1 journal
Along with 1 balance shaft gear ground up from a loose shaft bushing and the balance shaft drive gear missing a few teeth
Is this a common problem with this style engine?
It was previously rebuilt by Grindstaff engines so everything else looks fairly new
They must not have crack checked the crank before installing
You can clearly see it was cracked for a while.
Chipped tooth
Re: Waukesha D176 crank failure???
Post by Chipped tooth » Sun Dec 20, 2015 10:25 pm
Forgot to mention it's Lpg model
exhaustgases
Post by exhaustgases » Thu Dec 24, 2015 8:25 pm
I have actually seen a lot of industrial diesel engines with front or damper end crankshaft failures. I think problems like that are from constant running under close to overloaded conditions, or could be from constant idling, I'm not sure.
Kevin Johnson
Post by Kevin Johnson » Sun Dec 27, 2015 9:38 am
I think intermittent firing during shutdown or startup from lack of maintenance will produce spikes that concentrate forces in these areas (likely high reverse torsion forces). On the 300 SDL (automotive) I think it was also the reason for the high failure rate of the serpentine belt tensioner.
Bossman
Post by Bossman » Sun Sep 25, 2016 4:38 pm
Chipped tooth wrote:Just picked up a Clark off-road forklift for the shop the other day that needs engine work
Could have been from fan belt being to tight seen it many times crank breaks on #1 because crank is being pulled up wards by to tight of a fan belt shaft is turning off center and breaks
