Best Lube for Window Mechanism
chimpvalet
Post by chimpvalet » Fri Jul 08, 2016 12:34 am
I've disassembled the '70's era GM power window mechanism from my '79 Lotus and ask what lube would be best for the regulator gear and motor pinion bush points. I figure a light oil for the nylon track rollers.
Cheers
crazyman
Re: Best Lube for Window Mechanism
Post by crazyman » Fri Jul 08, 2016 1:34 am
I like white assembly grease for the rollers, and whatever grease you stick in the motor is way better than petrified 1979 grease.
Walter R. Malik
Post by Walter R. Malik » Sun Jul 10, 2016 11:16 am
Something with paraffin in it.
VegaJohn
Post by VegaJohn » Sun Jul 10, 2016 2:24 pm
Fluid film is what I use.
FLYIN FINN
Post by FLYIN FINN » Sun Oct 30, 2016 10:56 pm
I have been told to use Loctite Viper Lube
