Superflow SF-901 DOS Software
ar0884
Post by ar0884 » Sun Sep 18, 2016 7:17 pm
Hi,
I am trying to upgrade the computer on my Superflow SF-901. How do I transfer the DOS software that is currently in my old computer to the new one? Is there a download available anywhere? I have tried searching but have had no luck. Also, if anybody else has done this before please let me know if there are any tips that may help me. Thanks!
Greenlight
Re: Superflow SF-901 DOS Software
Post by Greenlight » Fri Sep 30, 2016 8:47 pm
As far as I know, you can't run a DOS program on a newer computer without having a DOS Emulator program installed.
I have several DOS programs that I run on my laptop with Windows 10 installed. I use a DOS emulator called DOS Box. It is available free online.
Project Greenlight
crazyman
Post by crazyman » Sat Oct 01, 2016 5:26 am
http://www.pcworld.com/article/243718/r ... ows_7.html
You might find a 7 update easier with more capabilities.
Funnycar
Post by Funnycar » Sat Nov 26, 2016 11:49 am
If anybody has more information on this or you find it out it works I would also like to do the same, I don't have a disc just the software that is already in my pc, and I am worried when it t crashes I will be in a bind.
Thanks
Kevin Johnson
Post by Kevin Johnson » Sat Nov 26, 2016 9:25 pm
http://www.computerhope.com/issues/ch000022.htm
MS-DOS and the Windows command line
xcopy command
Using the xcopy command you can copy the complete contents of a drive to another drive. An example of a command that can be used is shown below.
xcopy c:\ d:\ /h/i/c/k/e/r/y
In the above example the xcopy command would copy all of the files on the C:\ drive to the D:\ drive.
Funnycar
Post by Funnycar » Sun Nov 27, 2016 10:32 am
Thanks for the reply
I will give that a go and see if I can make it work
Thanks again
