Benefit to a wider wheel?
FastBuick
Post by FastBuick » Mon Oct 10, 2016 12:09 pm
Is there a benefit to running a 15" wide wheel with a 14" wide treadwidth and 16.2" section width tire? And if so what are they?
PAC Racing Springs Authorized Dealer
Independent T-1 Certified Amsoil Dealer
Wix Filters Dealer
Greenlight
Re: Benefit to a wider wheel?
Post by Greenlight » Tue Oct 11, 2016 11:53 pm
1) The contact patch tends to be larger and remains larger for a longer period as you go down the track. Imagine if you had a two inch wide rim. The outer portion of the tire would tend to curl up and make the contact patch narrower as the wheel RPM increases.
2) The tire growth will be reduced, which will act like more gear (higher RPM) at the finish line. Again, imagine you had a two inch wide rim. As the wheel RPM increases, the narrow rimmed wheel will result in a much higher tire circumference at the finish line. This effect is exaggerated with a light car (dragster).
Project Greenlight
FastBuick
Post by FastBuick » Wed Oct 12, 2016 7:39 am
Greenlight wrote:1) The contact patch tends to be larger and remains larger for a longer period as you go down the track. Imagine if you had a two inch wide rim. The outer portion of the tire would tend to curl up and make the contact patch narrower as the wheel RPM increases.
Makes sense. So do you think there is a way to figure out how much growth you will lose? Do you think if you go from a 14" to a 15" wide rim you lose 1" of tire growth?
Wix Filters Dealer
Greenlight
Post by Greenlight » Thu Oct 13, 2016 10:49 pm
The change in tire growth will depend on the vehicle weight and tire speed.
Project Greenlight
