What rear end mounted 2-speed O/D's --
Transmission to Rear-end
Re: What rear end mounted 2-speed O/D's --
Post by pdq67 » Sat May 13, 2017 11:29 am
Jack,
I just PM'd you about buying your B&J 2-speed.
Post by pdq67 » Sun May 14, 2017 3:24 pm
Jack,
I want to buy the 2-speed!
Get back to me.
$350 and shipping?
Paul
Post by pdq67 » Fri Jun 16, 2017 12:03 am
PackardV8 wrote:
I will buy a B & J unit IF I ever see one at a swap meet!
OK, done deal. I've got a B&J unit ready to crate up and ship, $350.
jack vines
Jack,
I got it.
You ever figure out how it shifted, OR was shifted??
I assume that it is ready to run, right??
Please get back to me.
Thanks,
Post by pdq67 » Sun Jun 18, 2017 9:36 pm
I just got done taking it apart.
It is so simple, it's amazing!
The reason I didn't catch how it shifted was because the shift slider rod was all the way in and when I grabbed the bolt in it, it turned so I just didn't realize that all I had to do was push/pull it to shift the planetary gear dog clutches.
Sucker is heavy tho... I would say like 65 to 70 pounds or so? As well as long...
I'm thinking about a way to mount it to the front of a 12-bolt? Probably cut it down and add plates on both ends so that with a coupler, it will mount to the rear end.
Then figure out a way to do the same thing with the drive shaft u-joint end.
