AEM Infinity Ecu and base harness
In-Tech
Post by In-Tech » Tue Sep 05, 2017 6:53 pm
Check on ebay, the ecu goes for $1399.95 and the starter harness goes for $274.50. I took these in as a partial trade against other work and thought I would find a use for them, it's been two years so I might as well let someone have a deal on these. =D> All brand new in original boxes. I'll take $1200 for all, shipped(US). Check out all the features, it's a pretty powerful ECU. AEM also has plug and play prebuilt harness's for many applications if you don't want to make your own.
http://www.aemelectronics.com/?q=produc ... inity-6-8h
http://www.aemelectronics.com/?q=produc ... -harnesses
AEM Electronics 30-7108 Infinity-8h Stand-Alone Programmable EMS
Infinity-8h
The Infinity-8h is designed for high performance V8 crate engines and smaller race engines using high impedance injectors. It also features the same small footprint and single weatherproof 80-pin connector as the Infinity-6.
Features
The Infinity-8h includes all of the advanced features found in its larger iteration including the latest generation 200 MHz automotive processor that can process 400 MIPS. Airflow model based (VE) tuning eliminates lookup of many correction tables needed in previous generation ECUs. Flex fuel and multi-fuel capability on-board wideband air/fuel control map switching and knock control are included. Engine protection strategies include coolant temp oil temp AFR vs. MAP intake air temp knock or fuel pressure. Programmable drive-by-wire variable cam timing boost control nitrous control and traction control are included. Data logging up to 64GB via a removable USB is standard with logging rates up to 1KHZ per channel. The Infinity-8h is able to communicate with 3rd party dashes and loggers and is AEMnet enabled. All maps can be password protected. Its sealed enclosure and IP67 rated communications ports are suitable for engine bay mounting.
Wiring Harnesses-NOT INCLUDED
AEM offers a flying lead wiring harness for the Infinity-8h that is 96 inch in length and pre wired with power grounds a power relay fuse block wideband and AEMnet. A Plug & Pin kit is also available for the Infinity-8h that includes an 80-pin connector with cover 80 small pins 1 micro relay with pins and 30 sealing plugs. Many Plug & Play adapter harnesses for popular race vehicles are currently in development and will be available in the near future.
" Airflow model based (VE) tuning
" ECU Set Up Wizard simplifies start up
" Flex fuel compatible
" Multi fuel capable
" Drive by wire
" Variable valve control
" Multiple boost control strategies
" Nitrous control
" Map switching
" Internal Wideband UEGO air/fuel controller
" Dual knock sensing circuits
" Data logging up to 64GB up to 100 channels at 1KHz
" Outputs to 3rd party dashes and data loggers
" Industry leading data transfer speed (up to 480Mb/sec)
" Integrated engine protection strategies
" Sealed enclosure and IP67 rated comms ports
Specifications Infinity-8h
Cylinders: Up to 8
2-Stroke Engines: Yes
4-Stroke Engines: Yes
Injectors Low Impedance (Sequential): N/A
Injectors High Impedance (Sequential): Up to 8
Coils-0-5V Falling Edge: 8
VR/Mag Inputs: Up to 4
Digital Inputs: Up to 6
Drive-by-Wire: 1
H-Bridge Channels: 1
Knock Control: 2-Channel
Analog Voltage Inputs: Up to 9
Analog Temp Inputs: Up to 3
Internal Wideband UEGO Controller: 1
High Side Outputs: 1
Low Side Outputs: 6
Variable Cam Control: Up to 4
4-Wire Stepper Motor Control: Yes
Boost Control (RPM Time Gear VSS Switch Input Flex Fuel Content: Yes
Engine Protection: Yes
Launch Control: Yes
Nitrous Control: Single Stage
Traction Control: Up to 2-Wheel Speed
CAN Channels: 2
RS232 Channels (Dual use pins. Tx and Rx shared with 2 digital inputs): 1
Connector Pins: 80
Data Logging: Up to 64 GB
Weather Resistance: Yes Sealed Enclosure with IP67 Connectors
Enclosure Dims: 5.855 inch x5.55 inch x1.8 inch
Weight: 18.8oz/476.27g
AEM 30-3705 Infinity-6/8h Mini-Harness
Product Detail(s):
Brand : AEM
Part Number : 30-3705
UPC : 840879022846
Country of Origin : USA
Kit Includes:
80 pin connector with cover
80 small pins
30 sealing plugs
-Carl
In-Tech
Re: AEM Infinity Ecu and base harness
Post by In-Tech » Sun Nov 05, 2017 3:06 am
Bump, open to reasonable offers. I have other stuff to buy. :mrgreen:
-Carl
In-Tech
Post by In-Tech » Thu Dec 28, 2017 8:32 pm
End of the year. $1000 shipped
-Carl
In-Tech
Post by In-Tech » Thu Feb 01, 2018 2:54 am
Sold
-Carl
