Making a track car streetable
oldhead
Post by oldhead » Sun Sep 10, 2017 8:55 pm
I have streeting it 11 years,1980 malibu, it was a race only car, but that has changed, I drive it on long trips. It runs 8.70 at 157 with 1.30 60s. I am 81 years old and love the wheelies a 100 ft. long and more, IT RIDES HARD, Bottoming in the rear alot. Are the springs to light(Comp.Eng), there 100#. The car is 3570#. I dont want to hurt the track times. Oldhead
Quicker then most
oldhead
Re: Making a track car streetable
Post by oldhead » Mon Sep 11, 2017 6:50 pm
How far should the shocks be in there stroke at rest OLDHEAD
Quicker then most
lefty o
Post by lefty o » Mon Sep 11, 2017 10:16 pm
imo , it doesnt matter, as long as they dont bottom out while driving.
F-BIRD'88
Post by F-BIRD'88 » Thu Oct 12, 2017 8:36 pm
Which element is bottoming out or topping out? the springs or the shocks?
If its the coil springs then on that car adding Air Lift air bags to the rear springs can help a lot.
Let the air out when drag racing if thats the optimum.
If its the shocks you may need longer travel or may need different shock mounting to get the at rest
center position right.
or is the rear end bouncing squatting or lifting while driving. ( acceleration, braking , cornering, going over bumps or dips in the road.
Rear suspension control arm geometry set up for best drag race chassis reaction and weight transfer
probabily won;t be the best geometry overall for street driving.
Adding adjustability of that helps. The air springs assisting the coil springs helps in that area.
j-c-c
Post by j-c-c » Mon Oct 30, 2017 11:21 am
" I am 81 years old "
You are my hero :D
Post by pdq67 » Tue Oct 31, 2017 1:19 am
Hey ol' man, drop the pressure in the tires and you will be fine!!
He, He!!
I'm past 70 y/o myself!
pitts64
Post by pitts64 » Wed Dec 27, 2017 7:41 am
Dyno Don said it best," no such thing as a street strip car"....
In-Tech
Post by In-Tech » Wed Dec 27, 2017 7:52 am
Wow, there is actually fans' in the stands. :D
-Carl
