Which Is Faster - 600hp@6200 or 600hp@7100
statsystems
Re: Which Is Faster - 600hp@6200 or 600hp@7100
Post by statsystems » Mon Nov 06, 2017 1:14 pm
Stan Weiss wrote:
Mon Nov 06, 2017 11:40 am
So what did Chris say? From what I have heard the MoPar head is not as good as the GM head with the 10500 RPM rule. When there was unlimited RPM the MoPar's ran better but still had no advantage over the GM's.
Stan
That was essentially what Chris said. The Dodge head was designed with the TR in mind. They were short on runner volume (length) and they could make that up in the intake manifold. With the EFI and and rev limit it killed the dodge.
I wish I could find that interview.
Stan Weiss
Post by Stan Weiss » Mon Nov 06, 2017 1:26 pm
Frankshaft wrote:
Mon Nov 06, 2017 12:59 pm
No, from actually racing. Not using simiulators and assumptions, which come in handy don't get me wrong. But I know what's faster in the real world.
No comment on my cvt tranny reply to your question? It's a viable question, and a good example
Lets simplify this. Which Is Faster? - 600 hp @ 6200 RPM or 600 hp @ 6200 RPM
Based on the very limited information I have given I would say they are the same.
Now how about we talk about what differences in the engines would make one faster than the other.
I will start by wanting to know what peak torque was and at what RPM for each engine.
Stan
Warp Speed
Post by Warp Speed » Mon Nov 06, 2017 1:41 pm
Stan, you posted BMEP earlier for the two combos, what is IMEP doing in each?
Which is more important?
Stan Weiss
Post by Stan Weiss » Mon Nov 06, 2017 3:19 pm
Jay,
People were asking for someone to post some numbers or dyno sheets or graphs. I took numbers from a 609 ci engine that made more than double the 600 HP. I shifted the torque curve and applied a correction fact and printout numbers for 6200 RPM then did the same for 7200. The BMEP numbers were useless but I did not take the time to remove them. So no I would not say any of those numbers are real.
Stan
Frankshaft
Post by Frankshaft » Mon Nov 06, 2017 9:44 pm
Jay,
Stan
So, you for all practical purposes, made up a bunch of numbers that you admit aren't real to win your argument? [-X
digger
Post by digger » Mon Nov 06, 2017 10:46 pm
No worse than observing something and making a false premise
Cougar5.0
Post by Cougar5.0 » Mon Nov 06, 2017 11:13 pm
Seems after reading all the posts in this thread, the best answer is:
"It depends"
...with a lean going to the added drivetrain flexibility of a wider power bandwidth (and possibly energy storage/momentum conservation.)
Am I completely wrong?
Stan Weiss
Post by Stan Weiss » Mon Nov 06, 2017 11:24 pm
Jay,
Stan
L M A O
I never ran an simulations with that data. So I would have no idea what those curves would prove or not prove. The only numbers I used to do any calculations were 600 HP @ 6200 RPM and 600 HP @ 7200.
Stan
digger
Post by digger » Mon Nov 06, 2017 11:38 pm
It should be clear that the peak number doesn't tell whole story. What the hp is at say 10% below peak hp rpm and say 10% after gives a better picture but ultimately if you want to compare you need an actual curve otherwise You can draw wrong conclusions.
Eg of the power curve noses over real quick it isn't good and the op mentions nothing about what happens after the peak. In the real world it's important.
Post by MadBill » Tue Nov 07, 2017 12:01 am
But since the original question specified just peak power, the only assumption that provides a rational basis for discussion is that the postulated curves above and below the peak are otherwise proportionally identical. Therefore Stan's analysis is valid.
user-23911
Post by user-23911 » Tue Nov 07, 2017 12:48 am
Up to 27 pages of bullshit now.
digger
Post by digger » Tue Nov 07, 2017 1:06 am
Of course, but in the real world it never works like that so people claim otherwise. Ultimately it means they don't understand and you can't reach maximum potential if you don't understand true cause and effect
digger
Post by digger » Tue Nov 07, 2017 1:15 am
Imagine if instead of dumbed down (averaged) inputs the dyno tells you that you used true inputs like torque per cylinder as function of crank angle and tried to work out the force output at the wheel tyre interface by time it all goes through the drivetrain accounting for all inertias, stiffness and damping.
Then compare electric motor vs ICE for same hp and rpm
mk e
Post by mk e » Tue Nov 07, 2017 7:06 am
Exactly. If the only difference is the peak rpm and all else is proportional and set up properly then they are the same and that is all you can day with the information given......but that would be a very rare occurrence.
Normally you don't get to change rotating mass or transmission ratios or whatever to better match the engine rpm and are forced to get what you have working and that changes things a bit.....but there is no way to talk about theses things with just knowing the engine peak hp & rpm.
Mark
Mechanical Engineer
John Wallace
Post by John Wallace » Tue Nov 07, 2017 8:11 am
So out of all of these pages, no one has an engine with dyno sheet 600 HP at whatever RPM and someone else with a dyno sheet 600 HP engine at a higher/lower RPM peak?
:roll:
John Wallace
Pontiac Power RULES !
www.wallaceracing.com
