8.1 inch rod in stock block/stroke 350 and -----
GARY C
Re: 8.1 inch rod in stock block/stroke 350 and -----
Post by GARY C » Sat Oct 28, 2017 2:19 am
David Vizard wrote:
Sat Oct 07, 2017 6:08 pm
So after the uproar this simple post produced here is the answer to how this all goes together.
First the block;- This had new thick wall liners installed in every cylinder. Prior to boring to size the blocks water jacket was filled with concrete.
The bores were then prepped as accuratly as possible to the 5 different bore sizes than I most often use. Together with the long rods this is how the block will be used.
Firstly the pistons have the crown machined with a hole that will accommodate the rod coming through. The piston is then mounted on the rod upside down. With the wrist pin above the top of the deck it can easily be removed to allow the piston to be removed from the top of the block. The reason for this is so I can quickly access the rings and replace them as required. The rotating assembly will be turned over at about 200 rpm max (I did say as a clue that the rods would last almost for ever even though they are welded) The purpose of this 'fixture' is as a ring break-in and polishing machine.
Why go to all this trouble? Because my previous method was too time consuming and time is the one thing I am short of.
Using a proprietory oil blend the rings will not only be polished but also the surfaces will receive a very thin layer (about 100th of a thou) of hard ceramic coating.
Try this little exercise next time you build a short block. After it is all together get a long breaker bar and turn the short block over about a half dozen time as fast as you can. Now take a sniff of the block.The chances are you will smell burnt oil caused by the new rings micro welding to the bore. To produce that smell temperatures need to go significantly over 400 F. Just give this a thought for a moment. That micro welding goes on during break-in and only stops (or nearly so) after a fully developed inter-component surface and oil film has been generated. In essence the rings do the final machining on the bores.
Why am I going to all this trouble? easy answer I can't afford to reduce piston assemble to bore friction the way it is done on F1 engines so I have had to come up with my own affordable solution.
Not only does this ring break-in fixture polish and plate the rings but also can be used to measure the the turning torque as the block is supported at a level just above it's longitudinal axis. A torque arm to the frame holding the block allows for load cell output to register the turning torque.
So how well does it work? With the bores prepped in the manner I use which is a double deal (cross hatch applied first and then a very fine vertical platue finish on top) it works very well. In a worst case scenario it cuts friction in half and in a best case scenario it cuts it by over 75%.
For example the initial turning torque my 383 Chevy short block builds usually runs around 18-20 lbs-ft when done in a conventional fashion. Prepping them as described here the turning torque is typically 5-6 lbs-ft. As for wear, when used with a top quality oil, the measured wear is extremely low to non-existent. My Cup car Dodge engine had 1500 race miles on it and exhibited no measurable wear in rings or bores. In fact it looked like it had never been run.
Just a further note here. The ceramic plating on the rings won't micro-weld to the bore material.
DV
For PDQ!
GARY C
Post by GARY C » Sat Oct 28, 2017 2:21 am
pdq67 wrote:
Sat Oct 28, 2017 2:11 am
I haven't read the complete thread so David, just how are you installing an 8.1" long rod in a 350" SBC engine??
Curious minds want to know!
In the other thread about the big pistons, I have asked how much can the Dart block that will bore to 4.25" be offset bored for max. dia. cylinders"
If your referring to the one in the general forum that was someone making fun of this thread! Look up, I just posted what you was looking for.
Post by pdq67 » Sat Oct 28, 2017 10:23 am
Sorry, I guess I though DV was going to run it with an 8.1" long rod.
Thanks Gary, I just found it and read it over slowly.
Mark O'Neal
Post by Mark O'Neal » Sun Oct 29, 2017 3:48 am
sanfordandson wrote:
Fri Oct 27, 2017 10:09 am
Mark O'Neal wrote:
Fri Oct 27, 2017 4:53 am
Ive been getting the mahle rings for around 170 a set in the 1mm size. I didnt think that was bad at all. I'm going to try the CP bullet line this winter in a few motors. 1mm, 1mm, 2mm ring pack, last ported lightweight flat tops for $720 a set with rings. IIRC the mahles were closer to $800.
I used Total Seal pricing, 170 isn't bad at all.
You'll be happy with the Bullet line, they're nice parts. They do a few thing I don't care for a lot, but nothing that would ever stop me from using them. That, and just because it doesn't make sense to me, doesn't necessarily it doesn't make sense.
The problem I have with ring manufacturers is getting rings with a spread so I can use the same rings setup on a range of bore sizes....and with a consistent choice of top rings. Not everyone wants to run moly, not everyone wants to run steel.
tenxal
Post by tenxal » Sun Oct 29, 2017 8:02 am
A solution in search of a problem.
RevTheory
Post by RevTheory » Sun Oct 29, 2017 9:00 am
Apparently a big time-saver for ring prep.
Post by MadBill » Sun Oct 29, 2017 12:52 pm
After sixty years of engine building, I think David was likely pretty clear on the problem before coming up with this solution..
user-23911
Post by user-23911 » Wed Nov 01, 2017 4:22 am
Here's quick easy question(s) about seating rings (after reading comments on one of those ricer forums).
That's because that's what this topic is about?
Bedding in the rings.
If you've got a good block and it's still got a crosshatch, if you decide to change the pistons and keep the bore size the same........has anyone besides myself reused the rings without a problem.
A bad hone job with a ball hone is worse than no hone job at all?
True or false?
Modern engines with EFI don't suffer from bore wear like old ones did.
It's normal to strip them and still have a cross hatch.
For a road car / street machine.
benno318
Post by benno318 » Wed Nov 01, 2017 4:33 am
i have had a few modern diesels come in with cracked pistons from injector issues. apart from the piston with cracks, the bores appear excellent. of course, with most of these, the owner wants to spend as little as possible (if they didnt, injectors would have been replaced/serviced ages ago avoiding the problem in the first place)
one way i approach these jobs is to offer to simply replace pistons, refitting existing rings in the same bores, which means i dont have to strip the entire engine down to hone and clean everything properly. this saves many, many hours stripping the engine of all the timing gears, crank and everything else just to give a hone and cleanout.
works well - and if it wasnt using oil before, it still wont.
user-23911
Post by user-23911 » Wed Nov 01, 2017 5:24 am
Good to hear.
Yes...leaking injectors in diesels.
They do a lot of damage.
1KZ, 1KD. WLT. YD25. ZD30?
Getting back the this post.........
It's about seating the rings but in another block.
So in effect you're starting off with new rings.......using a spare block to machine the new rings.
Then remove them and fit them to the block they're going to be used in.
The new block?
That will be already honed?
SO the rings are machined by the block?
The block isn't machined by the rings?
Or a bit of both?
David Vizard
Post by David Vizard » Wed Nov 01, 2017 12:52 pm
Good to hear.
The new block?
Or a bit of both?
Slightly aside but here is an interesting bit of ring info I got straight from the 'Grump'. 'The second set of rings on a bore always make more power!'
user-29956
Post by user-29956 » Wed Nov 01, 2017 1:53 pm
Good to hear.
The new block?
Or a bit of both?
[*]The third makes 5 more horsepower than the 2nd set! [/i][/b]Not many people have been there though!
.......Vincent Dizziano
David Vizard
Post by David Vizard » Wed Nov 01, 2017 2:39 pm
Good to hear.
The new block?
Or a bit of both?
Well Vincent, Did Grumpy tell you that or is it your opinion or a new 'old wives tale'?
DV
user-29956
Post by user-29956 » Wed Nov 01, 2017 2:53 pm
DV
Yes. CIRCA 1975ish. Ive also tested it many many times. Your free to ignore it of course though. I don't have to give these things away for free you know!
GARY C
Post by GARY C » Wed Nov 01, 2017 9:42 pm
I like the signature quotes, one my all time favorite is.
"You know your winning when your competition resorts to childish behavior"
