8.1 inch rod in stock block/stroke 350 and -----
David Vizard
Re: 8.1 inch rod in stock block/stroke 350 and -----
Post by David Vizard » Sun Nov 05, 2017 11:27 am
This ring processing 'machine' is moving along slower than I'd like but here is a piston and rod at TDC in the block.
I see a lot of comments about bedding in the rings. This setup is not about bedding in the rings it's more about not having to bed the rings in at all.The current top hi-tech engines do not have a honed bore finish or rings that 'bed in'. Sealing is near perfect and life expectancy is off the chart. The bill looks like a telephone number with the area code left off!
On my setup the rings will have a super highly polished ceramic coated finish and that will be about the best I can do on my budget.
DV
David Vizard Small Group Performance Seminars - held about every 4 weeks. My shop or your shop. Contact seminar organizer at marvingvx@gmail.com for details.
Post by MadBill » Sun Nov 05, 2017 11:33 am
Ah, a subtle but important distinction David: your rig is in essence an additional final step in ring manufacture, not a part of the engine build/prep!
David Vizard
Post by David Vizard » Sun Nov 05, 2017 11:42 am
Now if I had thought to put it that way there would have been a lot less confusion!!
Thanks Bill,
DV
Carnut1
Post by Carnut1 » Sun Nov 05, 2017 11:44 am
You know someone will mention that piston is upsidedown!
RevTheory
Post by RevTheory » Sun Nov 05, 2017 11:49 am
Followed by some sarcastic emojis, lol.
GARY C
Post by GARY C » Sun Nov 05, 2017 12:19 pm
There is an old saying along the lines of "Shouting a man down before hearing what he has to say is the greatest form of ignorance".
I wish I could find the actual quote...My guess is, Madbill has it. :D
I think it's something we could all work on.
RevTheory
Post by RevTheory » Sun Nov 05, 2017 12:34 pm
It's a long rod apparatus so you don't have to use your hands :D
RAS
Post by RAS » Wed Nov 08, 2017 7:00 pm
David has some free time on his hands. Maybe way to much free time.
David Vizard
Post by David Vizard » Wed Nov 08, 2017 9:14 pm
You are joking of course!!!!
DV
cgarb
Post by cgarb » Wed Nov 08, 2017 9:24 pm
A true dedicated hot rodder would attach the piston to a stick and burnish the rings in the bore by hand. The whole automatic function is way overated. Plus think of the workout you would get. No need for cardio at the gym...got 7 more sets of rings to finish...lol.
GARY C
Post by GARY C » Wed Nov 08, 2017 10:04 pm
Denny the owner of Motor Machine from your state told me in early 2000 "If you want to work with David you better pack a lunch" Denny has long since retired!
Cubic_Cleveland
Post by Cubic_Cleveland » Wed Nov 08, 2017 10:27 pm
DV
Can’t be bothered reading through the 18 pages of waffle, so can you give us a run down on the ring process again please? I’m ASSuming you have the rings coated, then finish/polish them in bores prepped the same way in the long rod engine as the actual engine they will be run in?
GARY C
Post by GARY C » Wed Nov 08, 2017 10:40 pm
DV
It's copied to the top of the previous page.
kimosabi
Post by kimosabi » Thu Nov 09, 2017 4:57 am
Any piston rock to be expected, or am I wrong for thinking that could be an issue for finsish surface of the rings.
Cubic_Cleveland
Post by Cubic_Cleveland » Thu Nov 09, 2017 5:26 am
Thanks Gary!
