Best way to remove an exhaust seat
Racerrick
Re: Best way to remove an exhaust seat
Post by Racerrick » Sun Oct 08, 2017 7:44 am
the easiest way is to use an old valve. If you don;t have a valve. drop a bolt with a large head down the guide then a washer that loosely fits the seat id then 3 welds mig or stick are fine about 3/8-1/2 long to the seat and washer. then tap it out.
mk e
Post by mk e » Sun Oct 08, 2017 9:20 am
cgarb wrote:
Sun Oct 08, 2017 1:33 am
Ahhh...now to go buy the Tig welder...lol. I have a mig, with creative shielding and some antispatter spray I'll make something happen.
Thats how I do it....and I have a tig. I take an old valve and grind it to drop into the seat then mig weld mostly on the seat, a little on the valve then tap the valve to pop it out. Hit the seat with a hammer to get it and most of the weld off the valve, on to the next one.
Mark
Mechanical Engineer
ZEOHSIX
Post by ZEOHSIX » Tue Oct 10, 2017 12:43 am
Just used the "TIG welder trick" to remove some tapered steering head bearings on a motorcycle restoration Im doing....makes the job soooo much EASIER! Valve seats....TIG welder!
