Rebuilt TH400 sluggish 1-2 shift.
Transmission to Rear-end
Roadknee
Post by Roadknee » Sun Oct 29, 2017 11:45 pm
I recently rebuilt a TH400 for my '79 BBC truck. The core trans came out of a running '81 6.2 diesel motorhome. I bought a complete kit with all the bushings, seals, torringtons, Alto high energy frictions and regular steels. I bought new roller clutches and the kit to rollerize the rear thrust. I installed the TransGo 400 1+2 kit with the heavy clutch springs but retained the stock pump relief spring. I initially drilled the 1-2 hole to 0.0.095" and the 2-3 hole to 0.082" I assembled the trans using the ATSG manual. I installed it in the truck and got the following pressures:
Neutral 80 psi (spec 55-70)
Drive 80 psi (spec 60-90)
Drive "2" 165 psi (spec 135-160)
Reverse 140 psi (spec 95-150)
The trans seems to function well, upshifting and downshifting as it should. The WOT 1-2 shift is pretty soft. The WOT 2-3 shift is perfect with a good firm bump on the shift. I drilled the 1-2 hole to 0.113. It firmed up the 1-2 shift some, but it's still pretty soft. The BBC is a worn out 7.5:1 468 that makes 350 HP on a good day. I don't think the 1-2 feed hole needs to be any larger. Is there anything else I can check?
77cruiser
Re: Rebuilt TH400 sluggish 1-2 shift.
Post by 77cruiser » Mon Oct 30, 2017 9:21 pm
Did you air check it before you put it in?
Jim
Roadknee
Post by Roadknee » Mon Oct 30, 2017 9:24 pm
No
dwilliams
Post by dwilliams » Thu Nov 02, 2017 6:35 pm
Did you write down the clearance of the 1-2 clutch pack? Too much can cause a soft shift.
kirkwoodken
Post by kirkwoodken » Mon Nov 06, 2017 11:14 pm
It's out of a diesel and you are putting it in a gas engined truck? Should be a completely different valve body than a gas car. Maybe a smart person will chime in. Never worked on diesel TH400.
Kirkwoodken
77cruiser
Post by 77cruiser » Wed Nov 08, 2017 10:04 am
What did you do for the modulator? Diesels have a mechanical one I think, hooked to a throttle cable.
Jim
Roadknee
Re:
Post by Roadknee » Fri Nov 10, 2017 4:20 pm
Clearance for all three packs was around 0.050"
Roadknee
Post by Roadknee » Fri Nov 10, 2017 4:22 pm
This one has a modulator. I installed the new one from the kit.
77cruiser
Post by 77cruiser » Fri Nov 10, 2017 8:57 pm
Is the modulator adjustable?
Jim
Roadknee
Post by Roadknee » Fri Nov 10, 2017 9:46 pm
Yes
Geoff2
Post by Geoff2 » Sat Nov 11, 2017 2:25 am
Modulator does not control shift quality, it controls shift timing.
amcenthusiast
Post by amcenthusiast » Sat Nov 11, 2017 6:10 pm
Ah, I'm almost certain to know what is causing your problem:
Apparently, the kit's recalibrated 1-2 and 2-3 shift springs are made to work with the kit's re-calibrated higher pressure pump spring?.. therefore the shift valves are not operating as intended by the maker of the kit?..
If I were you, I would install the shift kit's proper pressure pump spring ASAP to reduce slip with the new frictions and most likely cure the driveability problem as described.
IF you think most of the running clearances are 'good' and there are comparatively few 'loose' worn parts (like bearings or bushings), a thinner viscosity ATF may help to reduce parasitic drain on the pump caused by the stronger kit pump spring... hence a 'high peformance' ATF might not be a bad idea (study viscosity pros and cons and use your own best judgement)
XRV8 Race Parts > for AM's '56-'67 Rambler V8: http://amcramblermarlin.1colony.com/favorite_links.html
77cruiser
Post by 77cruiser » Sun Nov 12, 2017 9:18 am
Thought the modulator controlled line pressure too.
Jim
Roadknee
Post by Roadknee » Sun Nov 12, 2017 12:24 pm
You might be thinking of a different kit than I installed. The 400 1+2 kit recommends the high pressure pump spring only for over 450 HP AND race applications. My truck is probably 350 HP and street only. Springs are included to tune the 1-2 PART throttle shift feel. WOT shift firmness is adjusted by the size of the hole in the separator plate. There are no spring provided for tuning the 2-3 shift.
