Fram oil filters
Speedbump
Re: Fram oil filters
Post by Speedbump »
Used to cut many name brand new ones, as part of the Auto 1-2 technology program I taught where doing an oil change and service was required. After looking at product we would discuss advertising and it's affect on purchases and critical thinking skills at the lower levels. We always judged quality pf product and advertising quality. Wix always seemed to be on top quality wise but Fram almost always won the advertising part. Many of the young "gearheads" had heard of Fram but not too many had heard of Wix. Go figure.
Speedbump
The Radius Kid
Post by The Radius Kid »
Roundybout wrote: Wed Nov 22, 2017 1:48 pm There are a few sites (bobistheoilguy for that one) that people have cut open various brands and it's very informative how they're made. Some are crappy and glued together. Different filter media and area. Different bypass parts of cheap plastic.
This is one example of you get what you pay for. Seeing how inexpensive filters are and how vital, it's worth the couple bucks for a good quality filter.
That's true.
Here's a couple of tests:
http://minimopar.net/oilfilters/index.html
http://www.gmtruckcentral.com/articles/ ... study.html
91stang
Post by 91stang »
woody b wrote: Wed Nov 22, 2017 3:00 pm Personally I wouldn't put a Fram filter on my mower.
I wouldn’t put one on anyone’s mower.
1991 mustang 3040 with driver all motor all the time 9.70 @ 138.75 1.31 60' street driven mufflers and real tires, mt 275/60/15 radials with a 950hp holley.
BigBlockMopar
Momentary Specialist
Post by BigBlockMopar »
I would gladly put one on the neighbor's worndown, clapped out single piston noisy-as-hell mower...
BigBlocksOnTop2
Post by BigBlocksOnTop2 »
O'Riley Auto Parts, at least where I live at sells Wix. Maybe you have an O'Riley's where you live. I'm in Fredericksburg, Va.
BOOT
Post by BOOT »
Anything above stock oil pump or if the bypass is blocked I wouldn't use a fram, I know a guy where the fram came apart and clogged up his bearing passages. Killed his $$$$$ engine of course. I like Wix, Jomar and other good filters.
greg
Post by greg »
i have noticed all kleenex an toilet paper r made outta recycled paper its tougher though :lol: :lol: 8)
cv67
Post by cv67 »
x2 on blocked bypasses, due to clearance have to run that tiny Wix, dont stand on it til the oil is warm and thinned some.
Seems the ad giants always win, remember when you didnt hear much of Comp
Zmechanic
Post by Zmechanic »
If you have a blocked bypass I'd strongly consider an 51061r wix filter. It has a higher micron rating and will flow more. Since it lets bigger particles through so more frequent oil changes are a good idea.
82c10step
Post by 82c10step »
SupStk wrote: Wed Nov 22, 2017 3:07 pm I'm one who cuts open used filters. Do it on every new motor on the dyno. After comparing Wix , NAPA gold, Carquest (which are all made by Wix) to Fram, its easy to see why they are a couple bucks cheaper.
Carquest aren't made by wix anymore. After Advance Auto bought CQ they switched. I was disappointed.
turbo2256b
Post by turbo2256b »
a guy i worked with worked at fram. he told me the fram filters were called the "good to go filters" and put into a fram box and logo ie the ones that failed tests that were being specked to be branded for one of the big three or such.
S10LS2
Post by S10LS2 »
Baprace wrote: Wed Nov 22, 2017 1:42 pm IMHO they should be ok for street use.
Yep I know this is an old post, but it is at top of list, and I have must have missed this bullshi$ response.. But here goes,You know the op's street car is a 1000hp sbc that dips into the 8's right? He is not asking bout a 79 c10 to go pick up a half cord of wood.. As someone else posted later the real car guys know a fram filter that weighs about 8oz soaking wet is not adeqaute for a riding lawn mower.. :roll:
S10LS2
Post by S10LS2 »
Great post guy thanks for your contribution... =D>
Baprace
Post by Baprace »
S10LS2 wrote: Fri Dec 15, 2017 11:28 pm
maybe you should have reread the bullshit statement and thought for a min... I said they SHOULD be ok for street use, not WOULD be ok the op had already bought the filters so you have two choices use em or throw them in the trash, I've had more than one street engine come into my shop with a knock and the filters were always the cheap one's, like someone else posted the cheapies will collapse inside.
Sparksalot
Post by Sparksalot »
Filter wars are ridiculous without rock solid test data to evaluate the contestants. Is anyone here up to the expense of that testing?
