pressure testing station that has a sturdy locking rollover fixture incorporated into it's design.
it is large enough to test large i-6 jeep heads and small/mid size diesel stuff.
it can be used to pressure test blocks as well.
nothing is broken or locked up, everything works and it has all of the small individual block off plates of assorted sizes you will need to operate the unit.
It is on wheels and is built like a brick shithouse.
the working area within the fixture is 40" length x an adjustable out to 24" width.
you could set up v style blocks in this unit if you wanted to.
located in northeast Mass.
3500 picked up.
DCM tech pressure tester
Re: DCM tech pressure tester
seeing similar used setups going for less at a few of the popular equipment sales websites.
so, price drop 2700 or b.r.o.
