NEW 363ci STEELBLOCK BANDIT ENGINE
Phantom Race Engine # PRE364
SHP Pro Series block w/50mm cam bearings,billet main caps
Winberg billlet crank,3.375 stroke,Win finish,350 mains,1.850 IRL rods
Dyers 6" 300M rods w/Carr bolts
CP 4.135 bore pistons
Brodix T1 11 233 STS ported heads - 56cc
PSI XCES01 valve springs installed @ 2.015
Coated titanium retainers
Comp Cam 50mm 8620 billet roller cam LS firing order
Titanium 2.125 X 5/16 intake valves,50* seat
Titanium 1.600 X 11/32 exhaust valves,45* seat
Jesel 1.60 - 1.60 shaft rockers
Morel .937 keyway DLC coated roller lifters
NIEdelbrock 2925 ported intake manifold
MSD distributor w/capadapt
MSD crank trigger
ATI balancer
Scott spark plug wires
Stewart water pump
Jones serpentine pulley set
Champ dry sump oil pan
Clements billet aluminum valve covers
Bosch F09CSO spark plugs
14.58 compression
Valve lash - .016 hot
Timing - 36*
665hp @ 7300rpm
532# torque @ 6200rpm
Pictures & dyno sheet available by email
EMAIL: terry.marciaburnett@gmail.com
PHONE: 865-567-6943
$31,500 picked up here
NEW 363ci STEEL BLOCK BANDIT/TOPLESS OUTLAW ENGINE
Re: NEW 363ci STEEL BLOCK BANDIT/TOPLESS OUTLAW ENGINE
More pictures & dyno sheet.
