Chrysler RB build
AA Performance
Chrysler RB build
Post by AA Performance »
One for the Mopar guys as I have a 540 build for a customer and cant seem to find a listing for any "HX" series main bearings for the 2.750 crank journal.
I have seen the MS2233HG 3/4 groove and the MS1277HG full groove. I would prefer the 1/2 or 3/4 groove as I think that would be a better option but cant find any thing in a HX option. What are you mopar guys using for the 750 +HP range??
Thanks.
mag2555
Re: Chrysler RB build
Post by mag2555 »
Are you running a crank that's not cross drilled?
BillK
Post by BillK »
How much clearance do you want that you need the "X" bearings ?
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
www.enginerepairshop.com
AA Performance
mag2555 wrote: Mon Jan 08, 2024 6:04 am Are you running a crank that's not cross drilled?
Yes
AA Performance
BillK wrote: Mon Jan 08, 2024 6:43 am How much clearance do you want that you need the "X" bearings ?
.001" more than I have at the moment.
rebelrouser
Post by rebelrouser »
I used to like the King HP bearings, but I don't think they are available anymore. Last build I used the Speed Pro 119m 3/4 groove bearings. Knock on wood they are still working. When you own and race a Chrysler you don't have the luxury that Chevy guys do, many times you have to settle for what you can get. If you have an aftermarket block with priority oiling the oil issues are solved a 1/2 groove bearing will work just fine, If you are in the 700+ range with a stock block the cylinder walls and no. 2 main cap are your weak points, bearing problems are secondary.
gregsdart
Post by gregsdart »
Check ACL bearings. And i read bad things about cross drilled cranks! I have a 4.315 stroke, 4.50bore wedge with 572-13 heads, have had it to 8,000 rpm with a non cross drilled crank. Half groved mains at .0035, too much for aluminum block i am told. My go to guy says .0022 to .0025, due to aluminum growth at running temp. Currently apart after 20 dyno pulls and three runs due to a loss of prime on startup, to check things over.
1965 dodge Dart, 549 cu in wedge, 8.60 at 156 mph best. 2905 lbs, soon, 8.40s!
TMSJoe
Post by TMSJoe »
King has MB 5116XP-X, or MB 5116HP-X
My guy doesn't have them at this time.
Jerry Kathe
Post by Jerry Kathe »
Those king pn's are my first choice. None to be found.
I spoke with a sales rep a week ago and was informed no scheduled production on the books☹
