Lets talk about intake gaskets . . . . .
I think I am getting a little paranoid in my old age It seems lately on a few of the other car forums I frequent that there have been a lot of problems with the Fel Pro performance style gaskets with the blue rtv bead around the ports. Mainly it seems like they are moving out of place at the bottoms of the ports and in between ports. I dont know if it is really an issue or if it is installation error ? I have used those gaskets for years and have not had any issues that I know of.
I am putting together an almost stock 350 Chevy engine with cast iron heads. They have a Performer intake. If you go to Edelbrocks web page and look at the instructions it states "do not use competition style intake gaskets" because of this very issue. On this engine I am seriously thinking about just using the stock Fel Pro blue "hard" intake gaskets. They fit the ports and the intake just fine.
What are your thoughts ?
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
www.enginerepairshop.com
Waldorf Md
Re: Lets talk about intake gaskets . . . . .
Stockers for a stocker.
I have always used the metal-core blue Felpros whenever the ports were small enough for them to work.
DON'T PANIC
I don't know about gaskets moving, but I have had a problem of water wicking thru the gasket around the water ports on the last 2 sbc's I've build. Shows up at the top of manifold above the water ports as rust and white aluminum oxidation. One was Felpro 1205's and the other was Mr. Gaskets ultra seals.
But I can't rule out a warped/twisted intake manifold (ZZ4 aluminum). Anyway, the third set seems to be holding.
- New Member
The steel core Fel Pro gaskets with the -S suffix in the part number hold up well, especially on engines with siamese intake ports. The Fel Pros are only available in .065 thick. The only drawback is they are a nightmare to trim if they hang into the ports.turbo camino wrote: ↑Thu Jan 11, 2024 3:43 pm I have always used the metal-core blue Felpros whenever the ports were small enough for them to work.
Cometic made us some in the past in .045 and .060 thickness.
You're not paranoid. There are very few people that know how to properly check the fit of the intake manifold as to correct angles . It surprises me that some people continue the installation even when the bolts are not lining up. I have seen intake gaskets damaged before the install was finished.
I have had an intake manifold that did not properly crush a gasket side to side, top to bottom, and end to end when test fitting. Switch to another intake that was on hand and fit with proper gasket crush was excellent. There is a tool made for checking your angles although somewhat expensive. Felpro had an article written years ago how to test fit an intake using lead shot for proper gasket crush, top of the port , bottom of the port and end to end. Once you learn this procedure it becomes easy and eye opening.
A fancy gasket will not correct an intake that does not fit correctly. Of course the correct gasket needs to be used and the steel core gasket is good.
Block deck surfacing and head surfacing can change the angles. Warped intake manifolds can cause issues.
Agree with above about fitment... Also, looks to be waayyy... over-torqued bolts/ clamping pressure.
Sucked the wrong way, intake backfire ?Schurkey wrote: ↑Thu Jan 11, 2024 10:39 pm 2022_K1500_Intake_Gasket_08.jpg
This was the second time I replaced these. First set I blamed on me using the wrong gaskets--1205s. These are the correct port size for the heads--1256, I think. I was not happy.
Likely some of the pictures you’ve seen were mine BBC. I’ve installed my share of intake gaskets and never had a problem until the Felpro blue stripe gaskets. I will never use them again. I’m not a Felpro hater just the blue stripe gasket. I used their non high performance gasket to replace it and they were fine. It was not an installation error as so many want to point to. Other experienced techs have had them fail as well.
Had similar issues with a 1205 set. It was purchased during Covid, so I chalked it up to bad QC. But now you have me wanting to pull the intake and check. Thanks BillK.
One of my engines with the blue Felpros hasn't had the intake off since the last cam swap, which I am pretty sure was in 2001. L98 heads/ZZ3 intake.
DON'T PANIC
Had an eddy performer that sucked from the bottom, flanges wrong angle. Find it ironic eddy says it on their website LOL
Permatex 80062 gasket sealer but makes clean up take more effort/time. Some use that 3M emblem/trim adhesive but that's kinda extreme and a real pita to clean up i hear.
Had to enlarge bolts holes on several intakes, two eddy rpm air gap's on the same rear hole. The bolt would thread in but it was rubbing the hole enough that it would cause the flange to distort n leak when tightened down. Covered it in my intake prep vid https://youtu.be/xQpwhGJ1ID4
I'd still like to get that BHJ angle check tool some day but it's expensive! Felpro use to make a cheaper version but long discontinued. Prob make or have made, my own someday.
Manifold fit was fine. Block has not been decked, light cut only on the heads. Bolts line up perfectly.
I used the stock replacement Fel Pro gaskets. Its ready to go out the door Glad I was not the only one rethinking this.
Bill Koustenis
Waldorf Md
Waldorf Md
